Pull the fender.
Get a very long 3/8" extension. Money well spent.
You'll see how it comes off when you get the fender out of the way.
A word of caution. The factory setting for the master cylinder pushrod may not be the same as the new master that you put in. This seems to be a recurring theme. What this means is that even if you set the new pushrod locking nuts in the excact same position on the new cylinder as on the old one, the strokes may be different. Before putting the fender back on, make absolutely certain that the master cylinder is not retaining hydraulic pressure once released. If it is, the clutch will slip.
67 IIA 109" NADA Wagon (sold)
