I don't know what pulling the timing cover will tell you, any problem with things in there would affect all 4 cylinders the same, the cam timing would either be correct or incorrect for all the cylinders. Looking over your last post, you say you have compression on all 4 cylinders and spark on all 4 cylinders. That only (at least in my mind) leaves 2 things, spark at the correct time (re read some of the earlier posts about crossed plug wires) or fuel. If you have fuel, compression and spark at the proper time it will fire. Is it possible that something in the intake is blocking the back two cylinders preventing the fuel/air mixture from getting there? The reason I ask is that years ago I ran into a similar problem and found a shop rag had been left in the intake manifold during a repair and it was blocking off a couple of cylinders.
Gale Breitkreutz
'03 Disco
'74 Series III 88 (sold, 4/13)
'47 CJ2A
