Results 1 to 2 of 2
Thread: Mysterious Vibration
    Dec 2011
    Alexandria, VA
    4
    Default Mysterious Vibration
    I have a vibration at 50 mph in my '97 Defender. It's felt strongest through the steering wheel, but it's evident in the floor, etc. to a lesser degree. It comes in waves, slowly building up then fading out completely in about a 5 second cycle, followed by 5 seconds of no vibration, then repeating.
    I recently replaced the differential, all the U joints, balanced and rotated the tires, and had the front end aligned, but still it persists.
    Any ideas?
    May 2010
    Rutland, Vermont
    757
    Quote Originally Posted by sparks View Post
    Any ideas?
    check to make sure your lug nuts are all tight. Could be a tire balance issue. One way to rule things out. Drive up to 50 mph and the top of a hill. When you start going down put the truck in neutral and see if it still does the vibration. If its still there suspect tires or driveshafts.
