Results 1 to 2 of 2
Thread: Webasto 300 tdi
    Default Webasto 300 tdi
    Has anyone hooked up a webasto preheater on a 300 tdi. I am installing one right now, and not sure where to plum it into the coolant system. Any help appreciated.
    Dirk
    63 IIA 88
    64 IIA 109
    73 III 109 V*
    85 Defender90 300tdi
    May 2006
    Westford Vermont
    6
    I run the German Eberspacher Hydronic myself. The Wabasto seems
    very similar. I installed it according to Eberspacher's instructions; in the heater line coming off the rear of the cylinder head between the engine and the heater matrix. (Make sure you place the exhaust clear of your heater air intake) Leave your heater valve open and it pumps the coolant through the entire engine. Sub zero preheat takes about 20 minutes w/ instant heat and defrost. I use mine a lot to enhance cabin heat while driving. Its an amazing heater, a must have in northern VT. Hope this helps. m
