I have been trying to bleed my 109 brakes. This is the last step on my 109 dual brake conversion. I have added a brake booster and 109 dual master (prolines) from our host and some new lines. I cannot get any fluid started in my rear drivers side wheel cyl. I did crack the connector at the master and it will push fluid here. Checked for leaks none. Any ideas / similar experience??
Woked on this again, put a clear hose on the bleeder and had the wife pump the brakes. Still can't get fluid to start??
This should be way easier than this!!
