Results 1 to 10 of 10
Thread: Why are both my series 2 trucks hard to start hot??
    Dec 2006
    Front royal va
    227
    Default Why are both my series 2 trucks hard to start hot??
    Both trucks. One with a solex the others a zenith. Starts perfect when cold. Once the engine gets hot they both seem to vapor lock and takes around ten seconds of cranking before they will fire.. Any ideas???
    Mass.
    1,796
    How about your fuel lines? Are they routed in a way that keeps them warm or cool? How's your timing? Any smoke on start up? Color?
    It might be a vapor lock issue, which I had on my series IIA a few years ago. I drilled a couple of holes in the underside of the gas cap to allow air to get into gas tank as it emptied, and it cleared right up. In the meantime, when it's hard to start maybe just loosen the gas cap to allow air in.
    The holes were drilled on the inside, not all the way through the cap.
    Good luck.
    Tom
    Dec 2006
    Front royal va
    227
    The fuel line is routed just like they came from the factory. I timed both trucks a year ago. And they were in spec when I checked them. And no smoke upon start up.
    I will try the gas cap trick as well thanks!!
    Oct 2009
    norwich, ct
    587
    Mine does the exact same thing
    Aaron
    73 series III 88 2.5 na diesel daily driver
    67 series 2a 88 RHD sold
    88 RRC sold
    60 mga coupe
    May 2010
    Rutland, Vermont
    757
    You might try running heavier battery and ground cables to help boost the cranking speed. You might try putting a check valve in the fuel line just before the carb to keep fuel from draining back. Also you could try insulating the fuel line.
    I should have also mentioned that the better battery cables can improve spark performance. You could also install a hotter coil....are you running points or electronic ignition?
    Apr 2010
    Shoreline, WA
    408
    Mine's done this for a long time, I figured it was fuel peculating over into the intake putting it in a flooded condition, I'm too lazy to fix it so I just put the gas pedal to the floor when it's a hot restart situation (and keep it there) while I'm cranking, fires right up. I'd call myself a procrastinator but I don't want to rush into anything so I'll make that decision later.
    Gale Breitkreutz
    '03 Disco
    '74 Series III 88 (sold, 4/13)
    '47 CJ2A
    N. York
    1,635
    6.2.2 Hot Operation
    When gasoline vaporises prematurely in the fuel system, i.e., upstream of the
    carburettor jets or fuel injectors, operability problems may occur. The
    likelihood of the gasoline vaporising will depend on engine design, ambient
    temperature, ambient pressure and fuel volatility. Due to the higher vapour
    pressure of ethanol-blended fuels, the incidence of vapour formation in the
    fuel system is more likely than for gasoline fuels.
    http://www.environment.gov.au/atmosp...ubs/review.pdf
    Land Rover UK Forums
    Dec 2006
    Front royal va
    227
    I'm running points on both trucks.
    Quote Originally Posted by mongoswede View Post
    Not unless the existing ones are in really crappy condition, to the point of the engine not cranking.
    Tom Rowe
    Four wheel drive allows you to get stuck
    in places even more inaccessible.
    62 88 reg
    67 NADA x2
    74 Air Portable - The Antichrist (tag 6A666)
    95 D1 - R380
    95 D90 - R380
    97 D1 - ZF
