Yeah. I'm sure the manual says you should.
If I were in the envious position of towing around a 110 behind a large motor home, I'd get a set of locking hubs for ALL 4 CORNERS so you only have to unlock all the hubs for flat towing and don't have to be bothered with all the the driveshaft/transmission/transfer case/axle nonsense every time you want to tow it or drive it. You can go from towing mode to driving mode in 30 seconds if you're slow about it. If you have a partner, you could probably be down to 15 seconds. With three helpers, you will probably be done in just under 2 seconds.
