Front differential leaking
My 109 has RRC axles and I am about ready to dig into the differential to see what is the source of my leak/dripping.
All bolts have been tightened which seemed to make it leak more. The PO used some sort of silicone goop as a sealant...might be the problem. Is there a real gasket that is supposed to go in there? But I also have some play in the prop shaft going into the differential. Could be leaking from there as well. I assume there is a bearing and seal in there that might also need changed. Can i do this without a press or any special tool?
Thanks much in advance,
Derek
1969 Series IIa 109
She is ugly but she is mine...
