You need to be sure the door bottoms are aligned. The tops should seal once you do that.
You probably have reproduction door tops. Quality on those varies.
You could do some massaging to the bolts to make the door tops lean inward more.
I once over tightened the door top bolts and it made them bow out like that. I just loosened just a little bit and it solved the problem.
Sometimes it takes a little forearm and a well placed knee. Are you using S3 hinges? Check to make sure you have the plastic shim under the hinge on the bulkhead side
Jim
Welcome to series ownership
They leak
Aaron
73 series III 88 2.5 na diesel daily driver
67 series 2a 88 RHD sold
88 RRC sold
60 mga coupe
I am with Jim, I had to tweak both of my door tops on my SIII to get them to align properly. Start with the bottoms first, get them aligned first as also noted above.
THING 1 - 1973 88 SIII - SOLD
THING 5 - 1958 109 PU
THING 6 - 1954 86" HT
If those are stock type "flap" seals they will push your door tops out. They did on my SIII. Might want to look at the Defender style seals. They're foam rubber and form fit better.
1978 MOD 109
