The alodine is used for corrosion prevention and usually done in a bath but small spot areas can be done with a brush or rag then washed off with water. Alodine is most commonly used in aircraft manufacturing and a surface that has been worked say counter sunk rivet holes would be alodined before the rivets are installed. I first started my career in aircraft manufacturing and always had a small amount of alodine and a brush on the bench. As the body panels on our Landovers are aluminum it makes sense for them to be alodined as it provides very good corrosion resistance.
