Results 1 to 2 of 2
Thread: 2" spacer lift
    May 2007
    Colorado
    3
    Default 2" spacer lift
    How hard is it to install a 2 inch spacer lift? What are the disadvantages to lifting that much?
    Mar 2007
    Killingworth CT
    351
    It is not very difficult. It would depend on how stuck and rusty everything is. I would spray PB blaster or something on the bolts that hold the spring plates on, everyday for a few days before you tried to take everything apart.
    As far as downsides to the lift....none that I have found so far, I run it with OME heavy duty springs giving me about a 41/2" lift. body roll is not a big deal, that said I also do not have sway bars.
    If you only want a 2" lift I would suggest just getting springs, But If you already have OME springs it is cheaper to buy the spacer kit than to buy new 4 or 5" lift springs.
