Drive it for a bit. Keep an eye on it. Mine did this for a year before the fuel pump packed it in. It would have been easier if it just packed it in all at once.
Sometimes buy just tightening things up will the draw of unwanted air leaks into the fuel system, especially the base of the carb.
You know the old saying, " Timing is everything". I would check the timing make sure the distributor did not move.
I would also check the ignition coil and the wire going to it.
