I don't have parabolic springs but also have been toying with the idea of getting them. I do tow trailers of all kinds though with other vehicles and hitch/pin weight is very important, for a tag/bumper pull the hitch weight should be minimum 10% and up to 15% of the gross trailer weight. 120lbs would give a trailer and boat at 1200lbs total, any heavier and you don't have enough hitch weight. I can almost guarantee that if you tow there will be times you will hook something much heavier to the vehicle, I often move a small dump trailer 7-8000lbs loaded so my hitch weight is 1050lbs to 1200lbs, my 88 Landrover handles this no problem on the front or the rear. I tried this same trailer on the front of a 2006 jeep TJ with coil springs and it buried it. I'm trying to say if you tow at all don't stick some weak springs under it.
