I'm looking for the factory routing of the brake lines from the master cyl to the three way. A few pictures would be great
THING 1 - 1973 88 SIII - SOLD
THING 5 - 1958 109 PU
THING 6 - 1954 86" HT
anyone?
This is from the parts manual. It isn't exactly what you want but I think you can extrapolate the route pretty well from it.The pipes shown in the UL corner come from the master cylinder and go into the shuttle valve pictured right center. Front pipe goes to three-way T, and then to each side. Rear pipe goes to flexible hose that mounts on frame. The flexible hose goes to axle-mounted T fitting and then to each side.
If you are running a new system, you can probably safely delete the shuttle valve. I put in a Wilwood adjustable proportioning valve instead. I ran the front pipe directly to the T fitting.
what I'm looking for is a picure of the routing of the pipes along the bulkhead from the dual master to the three way for the front and coupling for the back. my brake switch is on the top of the brake tower.
I would also be interested in this as I am converting my single circuit IIA to a dual circuit with power brakes.
1976 Honda CB750F1
1974 Honda CB360G
1967 Series IIA
I will try to take a picture, but basically it goes from the MC back to the bulkhead, across, and down to the distribution block. The one for the rear then runs along the frame rail to the back. Pretty generic, I know, but if you have the old pipes in place or if they are missing, they just snap back into the plastic holders.
© 1974 Apis Mellifera. Few rights preserved.
I'll do my best to photo my dual (used to be single) line system tomorrow
Andrew
'63 SIIA 88" SW
http://hungrynaturalist.blogspot.com/
Rover Pics: http://www.flickr.com/photos/skunkal...7610584998247/
Just read your request. My '71 2a has the dual brake ms, and is LHD. I'll take a few pics of the brake line route this Sat. morning, but will not be able to post them until Tuesday morning. Hopefully that will help you in time. That will also give me time to highlight the brake lines (in Photoshop) so the route is easier to see amongst the typical clutter of wires and rusty surfaces!
David
Daily Driver: '71 2a, 88, LHD, Soft-top
