Originally Posted by
leafsprung
Part number is 561886 - 9/16 BSF x1.21/32 press in stud
Busboy - this is the press in late SIIA alternative to the thread in type you have.
-cheers -Ike
Les Parker... RN stocks that stud, # PLC405 @ $2.72 each.
Currently we have good stock.
It does mean removing the hub, though. Still, a perfect time to repack the bearings and check the hub oil seal, anyway.
Thank you both for your reply, after breaking out the vernier those two numbers seem the same at 1 21/32 (1.656) INCLUDING the head so the threaded portion is actually shorter than the screw in type stud which might work for factory rims but I need a pull in that has a threaded portion 0.150 longer than the original thread in ones so 1.8 inches minimum NOT including the head.
