Here's what I did with mine. It's a cockpit map light with a magnet JB welded to the base.
'67 sIIa 88
I use them to power my CB. I made plugs out of stainless cotter pins I had laying around. Works great with no overheating
Ted, I'm thinking that if the plugs are heating up in use then you are drawing way too much current. So you have the wrong bulb in your light, or something. If any part of your electrical system is getting hot then please please find the problem and fix it. The plugs are relatively big and heavy, imagine the wire behind them would be getting really hot!!
~Steve
---- 1969 Bugeye ----
---- 1962 Dormobile ----
Definitely could be the problem. i bet you could get a 12v equiv.
The work lamps were standard for the military and were offered as an option to civilians. I was very lucky to have been given one by a fellow Rover enthusiast as I had no idea that they even existed. I have purchased and resold several of these over the years but have always kept the one I was given. I have found mine very useful on several occasions. The really nice thing is that they are small thus easy to store and you don't have to worry about batteries corroding like a flashlight. The cord is long enough to be able to go front to rear on a 109. The work lamps are supposed to have the same bulb as a running light. It is possible that the wrong bulb is installed in the work light which is what is causing it to heat up. I have not thought about switching to a LED but that isn't a bad idea.
Jim is right about how useful and practical these lights are. Like many pieces of equipment that have military origins, they are (in a good way) way overbuilt: you can bash them around and they will keep working.
Our host sells Series and Defender back up (reverse lights). These would be easy to hook up as a dome or work light.
