Results 1 to 10 of 10
Thread: LED replacement bulbs
    Apr 2008
    West Virginia
    94
    Default LED replacement bulbs
    Does any one know if there are LED bulb replacements for the brake light, turn signal or tail lights available, and, if so, from where? I've seen color appropriate leds available for MGs and thought it might help with making the stop lights brighter. Thanks.
    Nov 2012
    Edmonton AB
    202
    To over come the small brake and tail lights along with the poor backup lights I installed 4 inch LED combo stop/turn/tail and 4 inch 55watt floods. I went with the combo lights because I also wired a trailer tow plug with electric brakes at the same time. You could actually use a 4 inch red and a 4 inch amber if you wanted to keep the independent turn signals. Not a very good pic of the lights as it was supposed to show the tire chains but you get the idea.
    Apr 2008
    Municipal Flatbock 18A, Linear North
    386
    I converted my entire truck (SIII) to LEDs a while back. I bought them on eBay. Much brighter. You'll need to replace the indicator and hazard flasher with one appropriate for LEDs.
    Apr 2008
    West Virginia
    94
    Busboy, you have a nice looking rig but I'd like to keep the original lights. Apis, where on eBay did you find the LEDs? In the Parts section?
    Apr 2008
    386
    Just search for 1157 and 1156 in the colors you want.
    Apr 2008
    West Virginia
    94
    Thank you.
    Nov 2012
    Edmonton AB
    202
    Quote Originally Posted by Walker View Post
    Thanks, and I know it's not everyone's cupa tea that's why I showed a picture. I wanted reliability first, size second, I don't know how others feel but it seems the Landrover doesn't get respect from other drivers, I used to almost get rear ended lots I even installed another set of rear lights mounted to the hard top but when the top is off you lose the extra lights. Going with these 4 inchers solved the problems I was looking to cure and they can be bought almost anywhere in a pinch.
  8. #8
    Feb 2010
    151
    Superbrightled led dot com
  9. #9
    Apr 2012
    Massachusetts
    58
    I'll second Superbright LEDS's as they seem to have better quality units are there is a lot of crap ou there. For signal, tail and tail/stop bulbs I'd only consider their 45 led 'tower' type 1156 & 1157's. These are very bright and importantly, the 1157's have a sharp difference between the tail and stop intensities. Some of the others range from barely adequate to dim.
    I went to mostly led's in the stock housings on my SIII. I left 1 incandescent signal on each side to work the flashers.
    I like the idea of bigger stop lights and, if you want to keep close to original, bright led bulbs in the NAS Defender round units are a good combo. Here is mine w/ the NAS Defender signals, I may yet get red lenses and use them for tail/stop:
Name:	LR rear any.jpg
    '72 Series III 88 "Greenie"
    '85 90 2.5NA "Stinky"
  10. #10
    I like that 45 LED tower for brake lights, but may try the 3W high intensity with lens for the other positions.
    Tom P.
    1965 exMoD 109
    1995 RRC LWB w/EAS
