Originally Posted by
TedW
I have a used dual brake master cylinder that fits my 1970 IIA with servo assist brakes. The master appears to be shot (rusty bore, stuck cylinder) but the tank is in fine shape (no sun damage cracks that often occur after a few decades of use).
Question: Is it possible to remove the tank from the master? The rear screws are easily removed, but it feels like a press-fit in the front that doesn't want to come off.
Thanks in advance for any / all replies.
Ted
My experience is the front has a square/flat oring type seal that is unobtainable, it does NOT come in the rebuild kit. I had to buy a complete new dual brake master AFTER spending $90 for the SEALED rebuild kit. I would suggest just buy a complete new master. Oh if you do want to take it apart it does just push in but may be corroded in and you will have to rotate it to break it free.
