Ever since I swapped the stock springs out for parabolics in my SIII 109" 3-door, my Rover has been about 1-2" taller in the rear than in the front. This is likely because I chose the 4 leaf heavy duty parabolics for the rear which provided more lift than in the front. I only chose the 4 leaf springs cause they were labeled as heavy duty...I couldn't resist.
Initially the extra lift in the rear caused my rear drive shaft to clunk inside of the rear crossmember. With new engine and transmission mounts and a new shaft, this was eliminated.
My rover is going under the knife pretty soon--the front crossmember is rusted out and the steering unit is caput, so my shop is going to cut out the front horn and weld in a replacement that I've found, and then the whole steering system (hopefully with the exception of the steering column) will be rebuilt--new steering unit, all new tie rod ends and new damper.
While this work is being done and the front end is out, I figure it is a good time to try and gain an inch or so of ride height in the front to try and level my rover out. I've read of the many potential issues of adding longer 1-ton military shackles to the rear of the front springs--pushing the front drive unit down and forward & messing up the geometry, which can bind or cause wear to u-joints and pinions or cause the shaft to hit the crossmember, and which can only be eliminated with shimming. The option to avoid these problems is to modify the front spring hangers to drop the front spring about an inch so that the spring remains level and geometry unchanged.
It seems like I'm in the perfect place to go ahead and have my shop modify the front spring hangers on my new replacement front horn (once it has been welded in) to compensate for the longer 1-ton shackles being added to the rear of the front springs.
So here is the question--should I have them hack and weld and fab the front spring hangers on the new horn to get the desired leveling of the spring, or can I have them simply fab (or repurpose/modify the shorter shackles that I'll be replacing) shackles for the front of the springs to level them out?
The other option is to remove the 4 leaf hd rear parabolics and replace them with the regular 3 leaf ones, hoping that brings the rear down some, but since I'm already having my shop rebuild the front end, and already have the 4 leafs installed and ironed out in the rear, it would seem counter productive.
What do you fellas think?
