A good question.
I too have my oil gauge tied into a banjo fitting on the 88". The 109" is a bit different. On the 109", my gauge drops to around 20-30 lbs. at idle. The longer at idle, the lower it goes. If left idling it usually will get no lower than 20. This is on the 2.6l six.
On the 88", I put in an oil pressure gauge off a tractor, it has no numbers, just yellow, green, and red. Yellow is labeled "low idle", green is "normal", and of course red is "high". I like this gauge, even though it doesn't have numbers. It usually never falls below midway on the yellow. If I had to guess, I'd say that that would also be around 20lbs.
If the engine doesn't make any knocking sounds when accelerating from low idle, I would think that you would be ok. Although, 10 does sound a little low. A thicker oil will help, but it could also be air in the oil gauge line. You can bleed the line by loosening the nut on the back of the gauge slightly while the engine is running.
I use 15w-40 in both engines.
67 IIA 109" NADA Wagon (sold)
