Hello!
I need to know the diameter of the hole that should be cut into a fuel tank to fit the Series style fuel level sender.
Anyone?
Thanks!
Tony
Hello!
Anyone?
Thanks!
Tony
2":
--Mark
No--that's the one tank I didn't CAD up and have done when we did the huge group buy. I didn't figure there was enough demand to hit the volume discount from the custom manufacturer. The drawing is of the flat top panel of one style of tank that sits under the seat:
--Mark
I still get a smile seeing those photos! Just need to get the new tank in still!
You mean modern Rover sender or a non-rover unit with a 5-bolt SAE pattern?
For the pictured tanks, I was going to originally use the modern 5-bolt SAE setup and universally-available senders, but something made me not do it--I want to say it was that modern 5-bolt senders read opposite of the series-compatible senders (high ohms=full tank on one system and high ohms=empty tank on the other).
If you mean modern ROVER senders, then a bolt-on sender is easy whereas a cam-locking sender is a huge expensive hassle in aluminum.
--Mark
BTW Tony--can't PM a reply--your PM mailbox is full.
.125 except floor = .250
--Mark
Tony,
Glad to hear you alive and still working on your truck!
72 SIII 88
67 SIIA 109
82 SIII Stage 1 V8
