SERIES 3 STARTER ISSUES
HI GUYS ALL CAPS IS BACK . TRYING TO START THE SERIES 3 AFTER ITS BEEN SITTING FOR YEARS , THE STARTER BAIRLY TURNS THE MOTOR OVER ,WHEN I TAKE THE PLUGS OUT AND THERE IS NO COMPRESSION IT TURNS LIKE CRAZY , I JUST HAD THE STARTER REBUILT AND THE PROBLEM IS THE SAME , I HAVE CHECKED ALL THE CABLES AND SANDED THE CONNECTIONS FOR NICE CLEAN CONTACT NO CHANGE , MY MECHANIC SEEMS TO THINK THE PROBLEM IS STILL IN THE STARTER . UNDER LOAD ITS NOT STRONG ENOUGH ,OFF THE MOTOR IT TURNS LIKE CRAZY, THINKING OF NEW SOLENOID AND CABLES ALL AROUND THEN SEE WE ARE TAKING THE STARTER BACK FOR A SECOND TIME TO SEE IF THERE MAY BE A SHORT UNDER LOAD , ANY THOUGHTS THANKS
