1966 Land Rover Type II 109 Wagon gasonline engine $8,500.00
SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD
THANK YOU !!!!
For Sale 1966 Lan Rover Type II 109 Wagon gasoline engine
This is a California car and has been garaged. It is a barn find or should I say a garage find. I put new battery in it drained the fuel put new fuel in changed the oil and it started right up! I am putting a carburetor kit in it and cleaning the carburetor. It has New exhaust system. New breaks, New cylinders all the way around. New Break fluid, New Master Cylinder, New Clutch Cylinder, New Water pump, New belt, New radiator rebuild and New coolant, New Oil change and filter, New Battery, Tuned. All wheel bearing have been packed and new oil seals on all wheels, All New Motor mounts installed, Comes with a set of new leaf springs, two new shocks. Wheel hubs are included as well as various other parts included.New Rear tow package unit. Mileage is undocumented as the speedo is not working but I have a used one ready to be installed. I have left all the dirt on the outside because it was stored in a garage for six years when I got it. No rust issues, No accident damage. It has been repainted in the past. Take a look at all the photographs. I have it well documented photographically and can take more for serious buyers. It will be ready for a test drive if you are interested and I can help with shipping if need be.
Contact Jim 916-947-6570 Northern California
1966 Land-Rover 109 Station Wagon Specs of Land-Rover 109 Station Wagon, model year 1966, version for Europe North America worldwide with 5-door wagon body type, 4x4 part-time (rear permanent, front engaged manually in off-road conditions), transfer case 2.35/1.15 and manual 4-speed gearbox. Basic www.automobile-catalog.com specs and characteristics: petrol (gasoline) engine of 2286 cm3 / 139.4 cui displacement with advertised power 50 57.5 kW / 67 77 hp / 68 78 PS ( DIN SAE ) / 4250 4250 and 168 Nm / 124 lb-ft / 2500 of torque. Dimensions: this model outside length is 4445 mm / 175 in, it’s 1676 mm / 66 in wide and has wheelbase of 2769 mm / 109 in. The value of a drag coefficient, estimated by a-c, is Cd = 0.9 . Standard wheels were fitted with the tires size: (see standard and alternative tire sizes ...). Reference vehicle weights are: official base curb weight 1702 kg / 3752 lbs, gross weight GVWR 2680 kg / 5908 lbs. How fast is that car ? Performance: top speed 100 km/h (62 mph) (declared by factory); accelerations 0- 60 mph 39.7 s; 0- 100 km/h 51.2 s (a-c simulation); 1/4 mile drag time (402 m) 23.8 s (a-c simulation) (see detailed performance data ...). Fuel consumption and mileage: official: , (see detailed fuel economy analysis ...).
Reason: SOLD
