Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Oil filter
    Jun 2009
    103
    Default Oil filter
    My 2.25l. Series II has the original canister oil filter but it came with an uninstalled screw-on conversion that I'd like to use. What is the required filter #? I don't see it on our host's site.
    Apr 2008
    The Granite State (NH)
    3,435
    The factory Rover spin-on adapter (and most of the aftermarket ones, I think) use:
    AC-Delco Duraguard PF2
    AC-Delco PFL1A
    Ace PH8A
    Apollo PH8A
    Baldwin B2
    Bowes PH8A
    Bucyrus Erie 46151593
    Car And Driver SF-1A
    Champion Laboratories PH8A
    Deutsch D539
    Econo Lube L30001
    Ford B7A-6714-A
    FRAM Extra Guard PH8A
    FRAM Tough Guard TG8A
    FRAM Extra Guard PH43 (shorter)
    Grand Prix PH8A
    Hastings LF115
    Hutchen SF-1A
    Jiffy Lube L30001
    Luber-Finer PH8A
    Master Parts PH8A
    Mitsubishi MO5281090
    Mobil 1 M1-301
    Mopar 3549957
    Mopar 5281090
    Motorcraft FL 1-3A
    Motorcraft FL-1A
    NAPA Gold 1515
    Penzoil PZ-1
    PowerFlo SL30001
    Purolator Premium Plus L30001
    Rockhill 61515
    Silverline 21515
    STP S-01
    STP S-016
    Target SF1A
    Valutest PH8A
    Warner PH8A
    Wix 51515
    Feb 2008
    East Quogue NY
    327
    Wow that's a great list. I've been using the Napa Gold units.
    Stick with the NAPA gold, or WIX 51515. Baldwin B2 is another good one.
    Don't use Rover OEM, it's a bad design.
    For the OP, make sure the one you have is a good one. Doug Richardson was making adapters in the 70's and someone took it upon themselves to produce a bunch of copies (I think it was of his) only screwed up and made them backwards so the oil flows the wrong direction.
    Tom Rowe
    62 88 reg
    67 NADA x2
    95 D1 - R380
    95 D90 - R380
    97 D1 - ZF
    Nov 2006
    Mass.
    1,796
    The filters are quite common which makes it nice. You can get them on the shelf at any parts store. The practical benefits of performing an oil change are a big plus IMO also.
    Jun 2009
    103
    Thank you Mark,
    As much as I enjoy the hot oil running down my arm, I think I'll make the change.
    A big competitor sells a spin on kit that I bought a long time ago for a series IIA. It turns out it fits on a 73 SIII NAS too. Pic below is the accompanying filter
  8. #8
    Apr 2008
    3,435
    I can tell you that with the factory spin-on filter on my 2.5 there's GREAT improvement: Hot oil only runs down your hands to your wrist, not your elbow.
  9. #9
    Nov 2006
    Flagstaff, Arizona
    1,087
    Quote Originally Posted by SafeAirOne View Post
    The LR factory oil filer adapter (spin on type) for a 2.5 will fit onto a 2.25 and replace the canister type adapter. It is probably the best adapter you can put onto a 2.25 but it is expensive and hard to find.
  10. #10
    I guess I'll need to go out to the garage and check, but I seem to recall one of the filter mounts to fit a Perkins 4.203 will fit the Rover 2.25.
    Tom Rowe
    62 88 reg
    67 NADA x2
    95 D1 - R380
    95 D90 - R380
    97 D1 - ZF
