Results 1 to 10 of 10
Thread: Ignition Coil Options
    Default Ignition Coil Options
    I have gone through 2 of the Lucas Coils in the past 10 years. Maybe this is normal or there is some other issue with my ignition system, I'm not sure. I am thinking I will try my luck with a non-Lucas coil. I am really hoping to find something that I can pick up at the local parts store. If I go with a different coil, do you know if I will need to re-gap the plugs? Does anyone have any suggestions for a good coil that I can get locally?
    Thanks in advance!
    Oct 2011
    Mountains of Western Pennsy.
    592
    Pretty much any high quality (Brand Name) coil will work. Just be sure they sell you a "Points" coil and not an "Electronic Ign" coil. I'm using an Accel high performance, high voltage on mine. No changes should be needed in either point or plug gap.
    '96 R.R.C. Lwb
    '76 Series III Hybrid 109
    '70 Rover 3500S
    Apr 2008
    The Granite State (NH)
    3,435
    Careful--all coils aren't the same. The primary windings on different coils have different resistances built in. Find out what the correct ohm value of the primary circuit should be for the engine and get the correct coil, lest you begin having other ignition problems (overheating/melted coil, burned ignition points, etc.) as a result of using the wrong coil.
    Check the posts by 'Bubbas Ignition' for some good information on coils here: http://www.fordbarn.com/forum/showthread.php?t=21781
    So does anyone know the proper resistance for the 2.25 set up?
    Nov 2006
    Mass.
    1,796
    Yup, the wrong coil can cause problems. I think the rover ignition system is a 3 ohm coil. I bought one from NAPA in a snow storm some 15 years ago and it's still working well. (knock on wood)
    That same snow storm is when I decided to ditch the stupid generator too! Lights on, both wiper motors and heat blasting = bad mojo!
    Jan 2008
    Portland, OR
    337
    Quote Originally Posted by I Leak Oil View Post
    Best upgrade, IMO.
    '67 sIIa 88
    Nov 2006
    Mass.
    1,796
    That and comfy seats.
  8. #8
    Apr 2007
    Scottsdale, Arizona
    889
    Napa model 905 is what I am running with standard dizzy and points. It is a 12V coil that says "no external resistor required" printed on the side.
  9. #9
    Apr 2007
    Scottsdale, Arizona
    889
    The part number on the box says it is napa part number IC64.
  10. #10
    Apr 2012
    Massachusetts
    58
    I had the same issue w/ new Lucas coils on my Tr6 and I went to Bosch coils on the toys. The Bosch "Blue" coil is correct for the Series, but not all Blue coils are the same, apparently Bosch may have several versions or suppliers. Pegasus Racing has the tried-n-true classic ones. Nice setup w/ a Pertronix.
    '72 Series III 88 "Greenie"
    '85 90 2.5NA "Stinky"
