Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Repairing holes in body panels
    Default Repairing holes in body panels
    Trying to determine the best way to repair the holes in the rear bodypanels caused by the steel seatbelt brackets. Was considering welding new aluminum repair pieces, but since I can't weld, seems a bad way to learn. A friend who is a professional welder said I would need to use some body filler anyway after welding. So do I just fiberglass the holes (I've made some bigger than needed by tinkering) or pop rivet aluminum pieces then Bondo? What's the best way to paint afterwards? Any help would be appreciated.
    Apr 2008
    The Granite State (NH)
    3,435
    If I had to do it and I didn't want to weld it, I'd probably just make aluminum flush patches and rivet them on using solid flush rivets, depending on the structure and access behind the holes.
    That way, you have to use a minimal amount of body filler and you don't have blind rivet heads sticking out all over the place and everything comes out looking flat and smooth.
    --Mark
    Apr 2012
    Bergen County NJ
    265
    Well, it seems like no matter what route you take you're planning on using filler.
    If they're small holes (under 1/2") then you could just use some filler, maybe with reinforcing fibers mixed in. Clean the back and maybe incorporate some glass cloth, yeah.
    If its bigger holes and you need real patching then yeah you could rivet pieces in and try to keep it all straight and flush. if you get a nice job done using rivets or even welds.... then do you need filler? It is a Rover after all, a truck that pries itself on not hiding behind facia panels and deep glossy paint. A neat riveted or welded repair deserves to be shown off IMO.
    Or get some scrap and practice for a month and learn to weld alum. <- best option.
    Or find another tub altogether.
    whatever you do, post some pics of the operation!!
    ~Steve
    ---- 1969 Bugeye ----
    ---- 1962 Dormobile ----
    Feb 2008
    East Quogue NY
    327
    Need photo(s). Holes in the body ?? That sounds normal, ignore it. Holes ("Honorable Scars") are better than Bondo.
    Apr 2008
    3,435
    Quote Originally Posted by Andrew IIA View Post
    Not these holes--I'm confident they're dishonorable crusty corrosion holes, by the description.
    --Mark
    Mass.
    1,796
    Mark is right,
    There are honorble earned holes and then there are shameful factory ingnorant holes....
    Jason
    Jul 2010
    Auckland, NZ
    451
    As an alternative, you could also consider gluing a small piece of aluminium on the reverse side of the hole with epoxy glue, then bogging over that. No rivets.
    Guess it also depends on how many rough tracks you intend taking it across. If any, ever.
    Alan
    109 Stage 1 V8 ex-army FFR
    2005 Disco 2 HSE
    http://www.youtube.com/user/alalit
    Unfortunately the holes are not honorable and I've only made them worse several years ago when I was considering the work. I would prefer to avoid bondo and may try the welding - one more reason to buy a new toy. Will post photos when I can.
    Jan 2007
    Burlington, VT
    66
    Chris,
    The new toy will be VERY expensive (tig welder, do not buy a mig with a spool gun, it will not work on thin sheet aluminum, just not enough control), and welding aluminum is tough enough, welding old thin aluminum adds a whole new dimension. I've done quite a bit of it with a Miller Syncrowave tig, you will get some heat warping, but that usually doesn't look too out of place on a Series truck. I have seen some amazing birmabright welding done with oxy/acetylene......that takes a real old school welder with years of experience, but it's amazing when dome by a skilled person. So, clean up the holes, find yourself an old body panel you can use to make patch panels, then find an experienced welder and let him have at it.........far cheaper then dropping $2K plus on a tig machine.
ID:	8962Click image for larger version.
ID:	8963Click image for larger version.
    Google HTS 2000 aluminum repair. They have some pretty impressive videos (also on YouTube) of various aluminum repair demonstrations that look very good and almost too easy to believe. Old school technique with (superior?) new technology using special rods and simple propane torch. I have not used it myself (yet) but bought a basic kit to try on a crack repair in a cast aluminum finned oil sump. Might be worth a try.
