Hi All,
So I am replacing my carrier bearings in my salisbury rear axle. I looked up and as mentioned on Terri Anns website (not trying to throw anyone under the bus here), the bearings needed are a 382A and a 387A.
Sounds good.
So I pull the carrier. The races have 382S stamped on them. Huh.
So what is the difference? I guess my biggest concern is I already ordered the A stuff, but I might need the S stuff?
Is there a difference? If there is, what is it? My current thought process is that these are probably the bearings that came in the truck 40 years ago. So along the way someone said, "I have a better idea" and then they swapped over to the A bearings. If that is the case, then sounds good as long as everything fits up fine.
I'm looking for "There is no difference Max. Put em on and keep rovering."
