Results 1 to 2 of 2
Thread: Transmission front seal??
    Default Transmission front seal??
    Hello, I am replacing seals/gaskets in my transmission/transfer case. It is from a 67 SIIa, 4cy gas. I think it is a 'D' suffix trans.
    It looks like there is no front shaft seal (the shaft that goes to the engine). I took of the speedo housing, and will replace that gasket, but is there a front shaft seal? Looks like a bronze ring where a seal would normally sit (in front of the baring). I intend to re-use the T/O bearing as it looks to be in good shape.
    Thanks!
    Jul 2013
    canada bc
    47
    i believe there is no front seal. i have one tranny on the floor and pulling another one out. i will take pics of this over the next week or two. and also pics of the damage of what not replacing a real good feeling throw out bearing looks like......remember.....dont look back you may not like what just fell off............
