Tried to start my 72 Series III but failed. Found zero fuel getting to carb. Cleaned fuel bowl and screen, used primer handle to try and fill bowl with no success. Added small amount of positive pressure to fuel tank and bowl filled and small amount of fuel reached the clear inline filter at the carb. Jumped for joy, but hit my head on raised hood. Tried the ignition, the engine sputtered, then just cranked. Never having used the fuel pump primer handle, should I feel some pressure as it's moved up and down?
It's the original fuel pump, to the best of my knowledge, and don't wish to waste money on a rebuild kit if I really need a new fuel pump to start with. Has anyone had this kind of experience, and how did you fix?
