I am at the final stages of tearing down Daisey and came across this creature mounted on the bulkhead behind the speedo. As you can see in the pictures the PO has done a substantial amount of creative wiring...what a freakin mess! I am in the process of trying to trace the wiring that was connected to the creature but figured someone may be able to tell me what it is?? It does not appear to show up on any wiring diagrams so I presume it was added by one of the POs.
Wording on the cover is "Francis Searchlights" Bolton, England. Terminals are marked "A", "B" and "L". You can't see in the picture but the two silver elements actually have windings around each one and connect to each other. The top of the siver elements appear to be a set of contacts. There is another small cover on the back with the wording "Flicker Flasher"...could it possibly be an aftermarket flasher for the indicators?
