69 109 p-up with an overdrive, military re-built 2.25 16" rims and a rochester and I easily cruise at 65 on the highway and 70 wasn't unheard of.
1969 109 P-UP
Hills are another thing though....
Rob
Bugeye88
1969 109 P-UP
Yep. I live at 7200 ft. and occasionally travel to Salt Lake which is 4200 ft. Going down is harrowing but I keep it down to 60-65. Going up I can go 40-45... 50 with a tail wind, with the Bugeye in 3rd overdrive. Not too bad. The engine is a 2.5 with 8:1 head, 34 ICT Weber, K+N and good tune. On the Flats.... mind numbing acceleration......
Rob
68 Bug Eye 88 Nellie Belle
The best way to check to see if you are getting your money's worth is to have someone press the accelerator pedal to the floor and hold it there (engine off) while you check to see if the linkage has opened the throttle all the way. Also if your timing is not advanced enough you will not be getting all the power you paid for. Either way a caution, slow moving vehicle sign is not out of order.
I had your power problem for the first 21 years I drove my truck. I solved it with a Ford 5.0. I now have more power at idle that the 2.25 had at peak and with some higher gearing have no problem keeping up with traffic in a 75 MPH zone. Oh, and I ended up with better fuel mileage
Teriann Wakeman_________
Flagstaff, AZ.
My Land Rover web site
So Teriann - would you rebuild mine for me then??? A 72 with a 2.25 engine! And yes, I made a sticker for the back that says "I'm going as fast as I can!"
1959 SII sold
1972 SIII RHD 88" (current project!)
Hey there! Nice to see another NM Series running around. Shoot a PM if you are ever in the Alb area. Apologies for the hijack...
Jeff
1991 Range Rover Hunter
Flagstaff, AZ.
Almost in keeping with the thread.
I'm thinking of driving the Blue Ridge Parkway northbound in the next few weeks.
I know the grades are crazy but I'm wondering more about the tolerance level of other drivers.
Have any of you been through in a Series? Are there lots of passing lanes?
I have more power than stock but I'm also towing.
Cheers
Peter
First of all... it's a beautiful drive and wonderful scenery - you'll really enjoy it!
The max speed on the parkway is 45, and it drops to 25 in some areas. It's also well patrolled to discourage speeders. Whenever I've been on the parkway, I've found most drivers respectful; but there will always be jerks out there. Fortunately, however, the BRP's status as a "National Parkway" means it is a route better suited for sightseers rather than thrill seekers. Besides, well known speed-routes are close by (like "The Devil's Tail").
That said... the steep grades and hairpin turns will make for a challenging drive in a series. There are no gas stations on the parkway... so plan accordingly. There are plenty of "Scenic Overlook" pull offs to give you and your series a break. On the longer, straighter, steeper grades you'll have passing lanes. If you haven't already done so, check out the BRP website:
http://www.blueridgeparkway.org/
They have plenty of resources/maps to help you plan a trip.
Enjoy!
Chuck
