Results 1 to 9 of 9
Thread: Amazing what you can accomplish in a month
    Default Amazing what you can accomplish in a month
    So I'm deploying in a few days and realized a couple months ago I have this monster of a thing in my garage in pieces. I started getting it back together but about a month ago it was barely reassembled and painted.
    Now finally today comes and I am finally done. It was a rush job but I am happy with how it came out.
ID:	9591 Click image for larger version.
    Only issue is it runs terribly. I couldn't get it above 45mph in 4th gear and it was screaming. It was in 2WD Hi mode so who knows what is up. Maybe falls back to the weak diesel CAV pump issue the prior owner mentioned. Either way I was able to get it to where I am storing it while gone so mission accomplished.
    Great effort!
    What's the story behind the roof and rear door? Is it a Santana?
    Tom P.
    1965 exMoD 109
    1995 RRC LWB w/EAS
    Mar 2010
    Banner Elk NC
    222
    Wow, you got a lot done. I think it looks great.
    Sorry I don't know diesels but others do on here. You will get it figured out.
    Aug 2008
    Portland, OR
    298
    What does it do at lower speeds/rpms? White/black smoke? Does it start easy(ish)?
    '67 109 NADA #413 - rebuilding w/ TDI & galvy chassis.
    Quote Originally Posted by luckyjoe View Post
    Great effort!
    Yup, Santanas have some weird quirks. There are safari style vents on the roof normally too but I just made some temp closing plates for now as they need some refurb work still.
    As for the engine, its noisy but I do not know how loud they usually are. Seems to emanate from the air filter housing the most. It behaves fairly fine up to 35mph but I am in 4th by that point. Takes forever to start (new glow plugs helped a bit but still issues) and the smoke varies. Heavy throttle creates black smoke but that's fairly normal from what I know of older diesels. I get white smoke initially but after a few minutes it goes away. Also the oil pressure light stays on but the oil level is fine.
    Here's a video I took of it running when I first got it. The noise is a bit amplified but it helps make it easy to understand.
    https://www.youtube.com/watch?v=3O4xNeZVysw
    Apr 2008
    The Granite State (NH)
    3,435
    Hmm.
    Was the air filter/air filter plumbing hooked up in that video? They're pretty loud through the intake when the stuff is hooked up and REALLY loud through the intake when the hose to the filter is off.
    How much blowby do you have when you remove the engine oil fill cap?
    Have you adjusted the valves to the factory specs? I would.
    --Mark
    Aug 2008
    Portland, OR
    298
    Yeah, I'd definitely check the valves. Smoke doesn't sound out of control, but it can't hurt to check the timing too - though that's somewhat easier said than done on these things.
    I hate to say it but the performance doesn't sound that out of line for a clapped out 2.25d. Mine could never to do better than about 60mph on flat highway with an overdrive or 50mph in 4th, even after I rebuilt the top end and replaced the injectors.
    Hmm.
    Everything was hooked up. I haven't made any engine adjustments at this time.
    No idea on blowby...or how to even test it for that matter.
    Apr 2008
    3,435
    Quote Originally Posted by AirmanPika View Post
    Its a judgement call really. When you remove the oil fill cap or the vent hose that goes from the rocker cover to the air intake system, does exhaust gas come flying out of the orifice like there's a hole blown into a piston, or dies it come out rather gently, like you've got worn rings?
    --Mark
