Results 1 to 6 of 6
Thread: 2000 LAND ROVER RANGE ROVER 4.6 HSE; BLACK ON BLACK
    Default 2000 LAND ROVER RANGE ROVER 4.6 HSE; BLACK ON BLACK
    BLACK ON BLACK
    FRONT BRUSH BAR
    FRONT DRIVING LAMPS
    REAR LAMP GUARDS
    RUNNING BOARDS
    ALL-WEATHER FLOOR MATS
    NAVIGATION SYSTEM
    116,000 MILES
    $3,700.00
    QUICK SALE - TITLE IN HAND
    10 MINUTES FROM JFK AIRPORT
    E-MAIL ANY QUESTIONS TO: 2000RANGEROVERHSE@GMAIL.COM
    THANKS!
ID:	8855   Click image for larger version.
ID:	8856   Click image for larger version.
ID:	8858   Click image for larger version.
ID:	8859   Click image for larger version.
ID:	8861   Click image for larger version.
    ADDITIONAL PHOTOS:
ID:	8864Click image for larger version.
ID:	8863Click image for larger version.
ID:	8865Click image for larger version.
ID:	8866Click image for larger version.
ID:	8867Click image for larger version.
ID:	8868Click image for larger version.
ID:	8869Click image for larger version.
    Nov 2006
    Cooperstown NY
    304
    Is it having some air suspension problems? Looks pretty low.
    Doug
    61 Series II 109 SW
    95 RR County LWB
    06 Range Rover
    98 Discovery LE
    THANKS FOR YOUR REPLY, DOUG!
    YES, THERE’S AN AIR SUSPENSION LEAK FROM A FRONT AIR SPRING, WHICH IS A COMMON PROBLEM THAT’S FIXED BY REPLACING THE AIR SPRING, WHICH CAN BE PURCHASED FOR AS LITTLE AS $150 FROM ARNOTT.
    THE TRUCK IS LOCATED 10 MINUTES FROM JFK AIRPORT.
    THANKS AGAIN!
    NEW PICTURES:
ID:	9663   Click image for larger version.
ID:	9664   Click image for larger version.
ID:	9666   Click image for larger version.
ID:	9667   Click image for larger version.
ID:	9669   Click image for larger version.
    ADDITIONAL:
ID:	9672   Click image for larger version.
ID:	9671   Click image for larger version.
ID:	9674   Click image for larger version.
