(Sold) 1972 Series 3 SWB Safari Station Wagon for sale (British Specs)
http://s64.photobucket.com/user/1sgwulf/library/
1972 Series 3 short wheel base (88 inch) Safari Station Wagon (K registration/ right Hand drive) $18,000 obo
77,070 original miles
Rover V8 engine (3528cc) from a Rover SD1 (190 HP) (probably 1978 origin). Will have a custom adaptor plate (probably Milner) to mate the engine to the gearbox. Professionally installed in England
Standard Series 3 gearbox
New clutch master, slave cylinders, and connecting rubber hose
Range Rover Differentials (Ratio 3.54 to 1)
Electric fuel pump (on main chassis rail under driver’s seat)
new 11’’ Brake Drums (3 inch shoes) with Long Wheel Base Servo assisted Brakes (careful, there are several types!) Also replaced all 4 wheel spindles and rubber brake lines to drums.
new Standard Series 3 radiator and copper plumbing
Kenlowe electric fan (switch controlled)
new Mt. Mansfield heater from Rovers North
High range transfer case (Standard transfer case and Fairey Overdrive comes with Land Rover if wanted)
Fairey Free Wheel front Hubs
new parabolic springs and Old Man Emu shocks
new tubeless heavy duty 16 inch slotted rims (steel) with new tubeless Michelin Tires (205/80/16)(including spare)
2 Rebuilt SU carbs to ethanol standard (10%) and new fuel lines with 2 fuel filters
Rear window wiper
galvanized steel frame and corner protectors
class 3 receiver hitch with wiring for electronic brake controller and 7 pin trailer plug
has new front seats with seat/shoulder belts and 2 seat belts on front 2 of the 4 rear seats
have 2 new side step also (not installed), rear step is new
new front lights and markers
wired in 4 way hazard switch
Landie is located in Denver an easily does 75 mph on highway
Reason: Sold
Originally Posted by
reduc
Beautiful!
Indeed, very nice, I'll ask around and see if any of my friends are in the market, also pop over to the Guns and Rovers board and post there as well, there were a couple folks there that were looking.
