Results 1 to 9 of 9
Thread: How identify my LR Series transmission or gearbox
    Jun 2008
    Puerto Rico
    18
    Default How identify my LR Series transmission or gearbox
    Hola everyone!!
    I need a little help identifying the gearbox that have my old LR Series III 88"(1972) 2.25 petrol. It is because I think the first owner change it. I need clues on how to identify its or difference from the ones of the LRS II, like serial numbers plate or where it is, how look in the exterior the ones from II or are alike looking, are the same exterior body? or if can publish photo that I can use like a guide when look mine. I know about the change in mechanic and synchro in the shift. If anyone can give me a clue, I will really aprecciate a lot and Gracias!!
    Ed Cintron
    Facebook/Land Rover Series Puerto Rico
    Apr 2012
    Bergen County NJ
    265
    Ed, I think if you took a few good pictures, there would be someone who could ID the transmission for you. The best way would be to find the stamped (not cast) serial# and post that. Im not sure what external changes were made.. They would probably be minor at best..
    a few good links regarding serial #'s
    http://www.seriesdiesellandrover.com...20Gearbox.html
    http://www.aulro.com/afvb/series-lan...earbox-id.html
    ~Steve
    ---- 1969 Bugeye ----
    ---- 1962 Dormobile ----
    Apr 2007
    Scottsdale, Arizona
    889
    The clutch slave set-up is different from the IIa to the III transmissions. see if you can get a picture of that.
    May 2011
    Dudley, Mass.
    329
    And if you can't get an answer here, try the Series 2 Club forum in the UK, there are many there that can narrow down the year of manufacture based on your numbers, give them your chassis number and the number of your tramsmission, and they can tell you the likelihood of it being the one it came from the factory with.
    Feb 2009
    Providence, RI
    455
    If it is a series III, the serial and suffix are on the top of the transfer case housing where the casing connects to the transmission.
    _________________________________________
    1986 3.5l 110 SW Austrian Feurwehr
    Jun 2008
    Puerto Rico
    18
    Quote Originally Posted by Revtor View Post
    ~Steve
    Thanks Everyone!!, during the week-end I will take some photos and publish its. I know for sure that the clutch slave is in the driver side(LHD) and when I shift first to second, i have to decrease speed or double clutch. And when i low from 3rd to 2nd it sound a little and have to decelerate.
    Ed
    Apr 2007
    Scottsdale, Arizona
    889
    I series IIa clutch slave should be on the passenger side, and is mounted vertically. I believe the series III setup is on the drivers side and is mounted horizontally. Someone with a series III might chime in. I don't think you can use a series III clutch mechanism with a series IIa transmission, but someone should verify this for me.
    Jun 2008
    Puerto Rico
    18
    Cool
    Quote Originally Posted by stomper View Post
    Thanks !!, I will take photos during the week end and publish its.
    Ed
    Feb 2009
    Providence, RI
    455
    Yes regarding SIII clutch horizontal on LH Side
