Ah ha, I always wanted one but never had one of those roof racks.Originally Posted by xrover
I like the idea of adding a sway bar to it then but not sure how you could best go about it.
Good luck.
Good luck.
I am tempted to take the roofrack off and forget about it all together.
I just like the look and plan to utilize it... That should truely make it sway a bit. Just like when Fred Flintstone's car turns on it's side at the drivethru.
Tim M.
Ashburnham, MA
P.S. good place to get the steel wheels? RN seems to have them but, I would be open to a used pair maybe even with tires already mounted.
Tim M.
Ashburnham, MA
WILMAAAAA!!!!Originally Posted by xrover
Tim M.
Ashburnham, MA
Ask around on the various boards- I used to need 16" wheels pretty badly then all of a sudden I ran into a couple deals which fulfilled my needs for an eternity... Rovers Down South has them new, as does RN and all other dealers.Originally Posted by xrover
I take mine off whenever I am not using it- It usually only gets used for a canoe anyway. For anything heavy I have the M416 trailer.
People often overload roof racks and they can make a bad situation worse in a hurry. Off road they are just a menace IMHO.
Originally Posted by yorker
Excellent little trailers!
1/4 Ton, but I've had over 1/2 ton in mine.
67 IIA 109" NADA Wagon (sold)
how about both?
A wider offset won't hurt, but the body roll issue is more likely the movement between the body and the platform (i.e. springs, shocks, swaybars) and not so much the movement of the platform and the road. This assumes your tires are adequately inflated, but you say they are. The roofrack (especially loaded) will just increase the movement between body & frameOriginally Posted by xrover
