Page 1 of 2 12 LastLast
Results 1 to 10 of 25
Thread: Causes for a seized engine?
    Oct 2014
    Carlisle PA
    82
    Default Causes for a seized engine?
    I am working on a '64 Series IIA. The other week, I replaced the fuel line which was clogged with rust, cleaned the fuel filter and carburettor. I managed to get it started and it ran for 15 seconds before stalling. Then I had my dad hold the throttle when I started it and ran it for about a minute. It backfired and was coughing back out the carburettor.
    The next day, I attempted to start it and the engine turned, would begin to fire, but didn't start. After a few attempts, I got nothing. Figuring the battery was getting low, I did some other things for a bit, but quickly realized the battery was fine. At that point, the engine acted as if it were seized. I pulled the starter and it was good. When I put in the hand crank, I was completely unable to turn the engine.
    While it acts as if it is seized, it wasn't running which is the typical case for locking up the engine. Besides the starter being stuck, are there any other things that might cause this?
    Apr 2008
    The Granite State (NH)
    3,435
    You don't say in your original post--when I first read this, I presumed that this was on some Rover you just hauled out of the barn after 2 decades of sitting.
    Re-reading it, it looks like it may be on a recently-previously-running rover?
    If so, then the only way things generally backfire out of the carb is if either the ignition timing or the valve timing is way out of whack.
    If it's the VALVE timing, then there's the possibility that something is causing a valve or valves to remain open when they should be closed and a piston or pistons can't rise to their top dead center position because they're hitting an open valve. I'd have a look at the timing chain
    I figure that what I described is the worst case scenario and your valves are now all bent up and the piston tops have holes knocked in them from hitting the valves. The good news is that if this is NOT the problem, you'll experience a brief feeling of euphoria.
    If the backfiring through the carb issue is an IGNITION timing issue, then it's easy to fix by properly timing the ignition, but it doesn't explain the engine seizure.
    Does the engine turn backwards by hand? if so, do the valves move when you are turning it? If so, does the crankshaft rotate then come to a definitive clunking stop? Does it rotate with the starter removed?
    Oh, and I hate to ask, but was the transmission in neutral when you tried to rotate the engine by hand?
    Nov 2006
    N. York
    1,635
    I had one do something similar once, the timing chain got jammed, IIRC the pad it runs on came loose and jammed into the cam sprocket. It ended up breaking the end off the cam.
    Land Rover UK Forums
    Oct 2014
    Carlisle PA
    82
    Mystery solved!!! Once I popped the head off, it became fairly clear exactly why it got stuck like it did. At first this posed another mystery of how the lock washer got in there since it was too large to fit in the spark plug port. My neighbor suggested it may have gone in through the carburetor which is fairly likely. My guess is it dropped in when I first took it off to empty the stale gas.Click image for larger version.
    Apr 2013
    Park City UT
    167
    How about a pic of the head #2 cylinder. The Piston doesn't look too bad.
    Rob
    Bugeye88
    Hopefully you have not bent the connecting rod.
    Oct 2014
    Carlisle PA
    82
    As far as the history, the car had been sitting for over a decade with rust in the tank and a clogged fuel line. My dad had occasionally run the starter to make sure it still turned, but never started it. When I went through the troubleshooting after it stopped turning, one of the first things I did was to make sure that the transmission was in neutral and the overdrive, and 4 wheel drive were all disengaged. One thought was that the drive train was somehow still engaged, but I raised it and made sure all four wheels freely turn. I needed to do that anyway so I can get it out by towing it rather than getting a trailer.
    I haven't tried to turn the engine backward. Based on enough comments about never doing that, I decided it wasn't the best thing to do. I'll give that a shot today. With the exception of turning it backward, it sounds like any other check involves removing the head or timing cover.
  8. #8
    Nov 2006
    N. York
    1,635
    Quote Originally Posted by chuckstp View Post
    Did you pull the plugs and check the cylinders from there?
  9. #9
    Oct 2014
    Carlisle PA
    82
    I've had the plugs out and attempted to look in one with a submersible,2 an but its picture is better submerged. I probed w/ a screwdriver today and 2 & 3 are up although they don't seem to be at the same height. After removing the fan blade, I managed to get the engine to turn backward. Turning it forward again has a hard stop again, although no noise, but I can feel it quite clearly. Using the angle of the hand crank to measure, it looks like it goes freely and stops just shy of one full rotation. Regardless, I can feel it hit something in both directions.
  10. #10
    Nov 2006
    N. York
    1,635
    Did you pull the valve cover?
