Possibly a really dull question, but the hood on my 95 RRC SWB shakes/wobbles when I drive it on the highway or at speeds over 60mph. Is there something I can tighten or do to help this stop?
Thanks!
Thanks!
First Time Rover Owner / Black 95 Range Rover County Classic 3.9L bought Oct. '14 / 135K
Hmmmm...where to start? Is the latch properly adjusted and closing completely? Are the hinges worn or loose? Is there a wheel bearing or swivel ball worn? Are the tires balanced? Is there a problem with the CV joints? I think finding the source of the vibration most important.
'95 R.R.c. Lwb (Gone...)
'76 Series III Hybrid 109
'70 Rover 3500S
There should be an adjustable nut and bolt with a rubber buffer at each front corner of the hood. You may have lost one or both of the buffers. Adjusting these may help with the hood shake.
Cheers,
pc
'95 RRC SWB Alpine
'95 RRC LWB Avalon
'06 E350 Sport
'87 HD FSLT w/ '02 Fatboy sheetmetal & wheels
'02 Hobiecat Getaway
I had these and they were awesome. Never another worry.
thanks everyone! tightened the nuts and bolts and seems to be doing better. still going to replace those rubber buffers. mine seems to be worn down pretty bad.
