Remove the grille on the front of the truck.
In the mess of wires under there, find where the big blue wire with a red tracer goes into the black rubber 4-way connector, along with the 2 smaller blue with red tracer wires.
Remove the wires and clean the bullet connectors and the 4 way connector's contact surfaces. Reassemble, (presuming the brittle metal on the inside of the 4 way connector has survived) then test low beams. If they still don't work, leave the lights on and mess around with the wires and connectors till good contact is made.
I'm very confident this is your issue, however, if it still doesn't work, check for 12 volts between the big blue/red tracer wire and a good ground and we'll go from there.
I'm sure somebody will be along shortly to say that the ground connections are faulty, but they're not.
--Mark
