Well...Next stop for the blue/red on the upstream side is the contact on the stalk where the headlamp power is switched to go either to the high beam wire (which it does) or to the low beam circuit. This happens on the upper switch on part #25 on the schematic I linked to earlier.
While you're under the grille, if you remove the fat blue/white wire from its 4-way connector and plug it in place of the fat blue/red wire on that 4-way connector then turn on the HIGH beams, do your low beams now illuminate (you're using the high beam wire to supply power the low beams to make sure the low beam filaments aren't both burned out)?
--Mark
