Misfiring on startup (when cold)
I would appreciate some advice on where to start looking for the cause of this issue...
When I start up my 1971 series IIa SWB (2.25l petrol), it runs rough (on 3 cylinders) and blows a bit of smoke (white) until it's warm. Once it's warm it runs really, really well (purrs even) and starts again perfectly. It has only started running rough when cold recently...
In the last 14 months I have:
- replaced the dizzy with a new one and put electronic ignition in it (Powerspark).
- had the (Zenith) carb reconditioned and tuned.
- taken the head off and replaced all valve seals and seated the valves (and replaced where necessary).
- replaced the HT leads and coil.
- replaced the spark plugs.
- set the timing.
Until recently it has been running perfectly (well, for a 2.25l LR engine!), so I'm not sure why it's begun to play up when I start it cold. (It starts easily and doesn't need any coaxing). I'm in New Zealand, so it's not the cold weather that's causing this...
Does anyone have any suggestions where I should start looking into the cause?
Cheers,
Warren.
'71 Series IIa "Horace"
88", RHD, 2.25 petrol.
New Zealand.
