Results 1 to 3 of 3
Thread: Radio Lock Out
    Question Radio Lock Out
    While doing some work in another part of my RR-P38, I disconnected the negative wire from the battery for such service.
    After the service was completed, I noticed that the radio had disconnected also and was asking me for the code to be entered. By mistake I entered the wrong series of number and it locked me out and now I cannot listen to music .
    Does anybody know how to reset a !@#$% radio so I can input the right code?, I have tried disconnecting and reconnecting it over and nothing seems to work.
    Apr 2006
    Vermont
    26
    Default Locked up radio.
    In most cases radios can be "un-locked" by simply leaving the vehicle powered up for about an hour. Either leave your key in the number 2 position or go for a long drive. Eventually, the message should change on the screen and you should be able to re-enter the code. Normally, I believe you have 4 or 5 attempts to enter the code before being locked out. Hope this helps.
    Arthur Patsouris
    Sales Manager
    Rovers North Sales Team
    Default code reset
    I found out from the dealer that all you need to do is hold down the BAND buttom until it asks for you to input the code and, VOILA, music.
