Results 1 to 3 of 3
Thread: Series IIa steering box rebuild
    Jan 2014
    Auckland, New Zealand
    78
    Default Series IIa steering box rebuild
    My steering box casing has cracked and I have sourced a complete replacement unit.
    Before I install the replacement box, I figure I'll strip it down, clean it out and give it a refurb...
    What are the issues that I'm likely to find?
    I'm thinking that while I've got it opened up, I'll replace all the loose ball bearings - but what do I replace them with...? Steel, Crome, stainless steel....? What size and how many will I need?
    Any and all suggestions appreciated...
    Cheers,
    Warren.
    '71 Series IIa "Horace"
    88", RHD, 2.25 petrol.
    New Zealand.
    Apr 2008
    The Granite State (NH)
    3,435
    Not sure about New Zealand, but this is a commonly available rebuild kit which includes the necessary bearings, available, presumably, from most Series Rover parts suppliers.
    --Mark
    May 2006
    2,020
    All the best for the All Blacks Rugby team in the RWC 1/4 finals !
    As Mark has said, these are available from many sources.
    The Genuine ones have lasted for 40 plus years, so I would go that route plus gaskets and the out put O ring.
    http://www.roversnorth.com/Land-Rover-Parts/58
    Les Parker
    Rovers North Inc.
