Going the P38 route and collecting the parts needed. Have a Saginaw canned ham type PS pump on the way.
I saw on TeriAnn's page that a 2-groove engine main pulley is needed but could not figure out why. Is it because the existing pulleys would not line up with the new PS one? Is it possible to align them since the bracket for the PS pump needs to be custom built any way? There is a lot of room above the alternator so I am guessing a custom bracket could be fabbed to position it on the same plane with the others.
Or or is it because you can't find a long enough belt to wrap all of the engine pulley, water pump pulley, alternator pulley, plus the PS pump pulley? So need to leave the existing pulleys and belt alone and just do a separate belt for the PS pump only?
Or other reason?
