stainless fasteners
Originally Posted by
cedryck
I can only add this to the plethora of good information already given, I concur that a new wiring loom from our gracious hosts can help eliminate some of the typical poor ground, and lights not working, horn not blowing, issues that older rovers with old original wiring present. The actual wiring of the truck was one of the easiest thing I have done on it, my 2 p, cheers.
Be aware some fittings need to be Grade 8 hardened steel, the yellowy looking stuff with the "8" printed on the bolt head. Stainless is fine for floors and things like that, but make sure to replace hardened fasteners with new hardened ones. Some anti seize paste will help if you ever need to get them apart again. (You'll have that silvery stuff everywhere during the process.)
Clutch and throw out bearing while you have the transmission out? It will never be easier. Stainless steel bleeder screws for clutch and brake wheel cylinders? Stainless flex hoses for the brake lines?
Good luck with your project.
Tom
Tom
1969 Series IIA 88"
I like it because I understand how it works (mostly).
