Results 1 to 6 of 6
Thread: Found: LH Door Mounted Mirror Bracket
    Sep 2016
    Virginia
    93
    Default Found: LH Door Mounted Mirror Bracket
    I have the RH and RN does not carry the mounting bracket. I am looking other places...but also adding it here.
    Consecutive drives without breaking down: 3
    Sep 2016
    Virginia
    93
    This is my RH mirror mount. I need the other one for the left. The backend where you screw in the holder is there, but the black cylinder that holds the rod is what is missing.
    May 2006
    2,190
    This Mirror arm should be attached to the top door hinge, this looks like it is bolted to the bodywork.
    Sep 2016
    Virginia
    93
    Quote Originally Posted by Les Parker View Post
    It looks like it, but it is attached to the hinge. There is an extension from the hinge with two holes for the mirror bracket. I will get a shot of the left hand side tomorrow so it is definitive.
    Sep 2016
    Virginia
    93
    Here is the left side. The bracket that connects to the hinge is there, but missing the cylinder and screws.
    Sep 2016
    Virginia
    93
    Ike got me one...no longer needed!
