Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Brake question
    Nov 2006
    Cooperstown NY
    304
    Default Brake question
    I'm doing a full refurbishment of a 1961 109 Station Wagon. I have completely rebuilt the brake system with all new parts. I have bled the brakes with a power bleeder 4 or 5 times. I am getting no air bubbles, and I have no leaks. It takes 4-5 pedal pushes to get the brakes to work. Once I release the pressure, the pedal goes to the floor again. 4-5 maybe 6 pumps, and then I get brakes. What am I missing? Thanks.
    Doug
    61 Series II 109 SW
    95 RR County LWB
    06 Range Rover
    98 Discovery LE
    Apr 2008
    The Granite State (NH)
    3,435
    Are the brakes properly adjusted with the snail cams?
    It is my understanding that most of the replacement brake shoes available today are junk. See this thread on G&R: http://gunsandrovers.com/showthread.php?t=9556
    Also there's the matter of having the rear shoes on incorrectly. See TeriAnn's page about this: http://www.expeditionlandrover.info/...rearbrakes.htm
    All these things (and a few unmentioned things) make the 109 brakes not work without many pumps.
    Nov 2006
    Cooperstown NY
    304
    I have the shoes on correctly as per TeriAnn's page. I think my problem is with the snail cams and the shoes. Is there an orientation for the snail cams? Does it matter which way they go on. It seems like when I adjust the snail cams, it doesn't push the shoes out far enough. Maybe it's the posts on the shoes not being in the right spot. I think the brake shoes are Delphi. One of the posts fell out also.
    Doug
    61 Series II 109 SW
    95 RR County LWB
    06 Range Rover
    98 Discovery LE
    Apr 2008
    3,435
    Quote Originally Posted by DGG View Post
    This is, of course, a huge red flag.
    Nov 2006
    Cooperstown NY
    304
    What about the orientation of the cams in the picture? Both cams have the flat side facing the top. Does it matter? The business where I got the brake kit is willing to replace the shoes if they are defective. I just don't know where to go from here. I'm doing a frame off restoration of this vehicle, and the only thing that is holding me back from driving it on the road is no brakes. Frustrating.
    Doug
    61 Series II 109 SW
    95 RR County LWB
    06 Range Rover
    98 Discovery LE
    Apr 2008
    3,435
    Diagram from the parts catalogue:
    Oct 2006
    1,199
    I can only adjust the rear brakes properly with the wheels off the ground...so I can tell how tight the adjustment is. I adjust the snail cams so that there is SIGNIFICANT drag on the wheel when you attempt to turn it by hand. Not so much that it is locked, but it must be hard to turn.
    I also find that the snail cam tends to get a flat spot which then makes the post on the shoe kinda slip back into this spot no matter what you do. Replacing the snail cams is the remedy. Our hosts have a kit. Be sure you put them on right way around.
    The rears on a 109 should lock up under a good stab with the welly.
  8. #8
    Nov 2006
    Cooperstown NY
    304
    looks like on the diagram that the snail cams flat edge is facing up. I think on my picture it shows one of the snail cams with the flat side down. I'm taking apart the brakes and starting over. Not looking forward to it. Any idea which way to turn the snail cams? Is it always clockwise or anti clockwise, or does it vary side to side?
    Doug
    61 Series II 109 SW
    95 RR County LWB
    06 Range Rover
    98 Discovery LE
  9. #9
    Nov 2006
    Cooperstown NY
    304
    I discovered a potential problem already. I downloaded the instructions from Britpart for the snail cam installation. I have the front brake cams installed incorrectly. I'll change that. The instructions also say that you may have to file down the bolt so there is clearance between the bolt and brake shoe.
    Doug
    61 Series II 109 SW
    95 RR County LWB
    06 Range Rover
    98 Discovery LE
  10. #10
    Apr 2008
    3,435
    ...Britpart...
    Red flag #2.
