I'm trying to install a VDO fuel level gauge. I have this sender: http://www.roversnorth.com/ProductDe...e=0&eq=&key=it
It's not working. I believe I have everything hooked up properly but when I turn on the key the fuel gauge pegs beyond full. I think I have about 8 gallons of gas in the tank. Not sure if the gauge and the sender are compatible. The gauge has an ohm range of 10-180ohms. If I disconnect the sender completely, I still get a pegged gauge. If I hook up directly from the battery positive terminal to the gauge, I get a pegged gauge. Tested the gauge as per VDO testing procedures, and the gauge is good. Not sure what I'm missing.
Thanks,
