Finding straight up GL-4 gear oil that is not, in fact, GL-5 seems to be tricky these days. What GL-4 oil are you using on your rigs that you are happy with (and able to easily source)?
Thanks.
Corey
Thanks.
Corey
~ Corey
1974 Series III RHD SWB
2003 Freelander
Tractor supply stores or your local John Deere dealership. I buy 90wt in 5 gallon pails. You use a garden sprayer with the nozzle cut off as a filler. Be sure to get one that lets you lock the trigger on. They're like $15. Put a pan under the fill hole stick the end of the sprayer in the hole, lock the trigger and let it do its thing until you see the oil overflowing into your pan. Neat.
stabil gl4 at Amazon
THING 1 - 1973 88 SIII - SOLD
THING 5 - 1958 109 PU
THING 6 - 1954 86" HT
What's wrong with GL5? I put a whole bunch of it in my Rover a couple months ago when I topped everything off. Shouldn't matter it already needs more!
