Results 1 to 2 of 2
Thread: P38 Cutting out while driving
    Default P38 Cutting out while driving
    Has anyone had this problem? It happens randomly and at different speeds. The entire truck cuts out. Ignition problem? Relay? At first I thought it was fuel related but the radio and dash panel cut out as well. Any insight would be appreciated, thanks
    Oct 2011
    Mountains of Western Pennsy.
    545
    Check battery connections and body grounds (earths). Also check starter connections as well. Clean and use di-electric grease on all connections after cleaning. Be sure to check and clean alternator connections.
    '99 Disco II
    '95 R.R.C. Lwb (Gone...)
    '76 Series III Hybrid 109
    '70 Rover 3500S
